I got a famous artist main amp and I'm trying to replicate it before I have to return it. I can't say who for the moment...
I have a donor amp that is same year not so far apart in serial but they sound quite different. The donor is a clean amp while the "artist" have seen a over 30 years of rock n roll( you can smell it!).
I have measured a lot of stuff and all the pots show less resistance but even matching them there is still a big difference. I narrow a big part of the difference to the first tube a 12 ax7a.
it just say 12ax7a, it have a reverse number 5 in the bottom, double mica in the top and a ring of getter residue around it. the Getter is a square solid metal piece and is supported by two wires. the upper mica looks riveted to the main structure. the bottom looks a bit cloudy and milky.
