I'm new to preamp design, but I'm good with a soldering iron. I have recently began building a preamp. I'm using a Balanced line transmitter/receiver to balance my I/O for XLR's. My preamp stage is a NE5532 op amp style circuit. I have 0.1uf Wima caps between each +/- power input on each op amp. I'm using all Wima (Film) 1% caps for the entire circuit. Resistors are all Vishay metal film 1%. My power supply is supplied using a Hammond 161G28 Transformer, .5% caps/resistors and 7812/7912 regulators. Decoupling is provided by Wima 0.1uf caps in entire circuit.
Input Stage TL071
Preamp stage NE5532
Output stage OPA2134
Power : Hammond 14v-0-14v with 7812/7912's
Balanced line transmitter/receiver schematic (http://sound.westhost.com/project51.htm)
The only exception is I'm using the OPA2134 in the transmitter circuit for it's better quality.
NE5532 preamp schematic (http://www.next.gr/circuits/Pre-MIC-microphone-preamplifier-2-CH-by-IC-NE5532-or-LF353-l40881.html)
Identical using all Wima/Vishay 1% components.
PSU schematic (http://www.electroschematics.com/6247/12-volt-dual-power-supply/)
Identical using .5% components.
My question is, what kind of quality can I expect from this. My soldering is neat and etc. How would it compare to the cheap preamps in a digidesign 002 for example? I'll be using standard recording mics like a SM57, 421 or 414. I hace phantom supply for the C414 as well will add one to the circuit eventually.
Input Stage TL071
Preamp stage NE5532
