Che_Guitarra
My next project is to build a 2061X 20W Marshall Lead & Bass amp - I plan to install a variable voltage regulator (VVR) over the power section and phase inverter. Here's the schematic i'm basing the build on:
Here's the same schematic with VVR installed. I'm happy it's OK, but if you can spot any errors i'm all ears. I'm also hoping some brighter sparks than I can work out the new resistor values I need across the B+ rail to maintain correct voltage. #2 and #3 might be OK, but i've highlighted them anyway:
Any input most appreciated.
