Help on C12 Build...
Can you look at the part number on the three terminal regulator the part with the small heatsink?  Is it a 7806 or a 7906 or something else?
Have the two zener diodes been changed to two 60VDC ones?  The part number can be looked up.
Can you take a picture of the microphone board(s) I am curious if this is a cathode biased microphone.
A C12 can be thought of as cathode biased microphone mixed with a RC filter to make it kind of fixed biased
I think tracing the grounding circuit will be very helpful to find the hum issue.
Gus, while this isn't my mic, these pics are identical to the mic I have:
http://www.m221b.com/AMI/C12CG/C12CGHI.html
I have examined everything, and it really does not look like the ground gets separated at any place.
I had a recommendation from Dennis at AMI/Tab, and he said that the power supply could possibly be modded to deal with the hum, at the expense of effecting the tone, and that I should use a grounded power outlet.
I looked at my 7 pin XLR cables, and ground does appear to make contact with the sleeve with the way it all fits together, with all of them. I didn't get into crimping the shielding as described… it wasn't immediately obvious how to do that without redoing the whole connector. I am going to dig into this more this weekend though, and hopefully resolve the problem somehow, probably by installing a grounded power receptacle.
GeorgeToledo said:
... and he said that the power supply could possibly be modded to deal with the hum, at the expense of effecting the tone, and that I should use a grounded power outlet.
Great way to convince a client not to fix his problem  ;). At the least I would ask them to clean it because all that dirt and dust can become conductive and short out components = dead power supply.
For the problem itself, can you post a picture of your (6-pin?) cable terminations? Unscrew the connector housings on both sides to show how it's wired.
I'll post pics of those connectors in just a bit, thanks.
I was planning on blowing out the power supply with a can of air. What would be the procedure for anything that doesn't blow out with that - something like alcohol and a q-tip?
Adding a grounded power receptacle to my old house wound up solving the problem. No extraneous noise at all, clear as a bell.
Best is a lint free cloth, and wipe clean with isopropyl. Compressed air cans release chemicals.
Q-tips for stubborn parts.
Another great tool for this kind of job is a paint brush. Priceless for cleaning electronics in general.
GeorgeToledo said:
Thanks for the tip!
I'm glad I hadn't used the compressed air yet.
