I found the same thing in the two data sheets that I had on file. I wouldn't recommend going higher than +/-20 in regular use.
That is a very odd conclusion given that OPA604 and NE5534 have the same pinout, but OPA604 can run at 4V higher supply rails. If OPA604 let the smoke out then NE5534 should do the same but a little bit faster.my conclusion is that this device uses OPA2604s and NE5534s
I just double checked and TL071 and OPA604 have the same pinout as well, so something else is going on. Put the sockets in backwards, connected the diodes incorrectly, diodes caused the first problem and did the same thing when put back, etc.since the TL071s didn't get smoked when testing
I just got the OPA604s and the OPA2604s and replaced the opamps, installed sockets, reconnected the lifted diodes, hit power and OOOOOOOPS all the OPA604s went up in smoke!!!...
I will check again but what I did was:Obviously something very bad has happened, because a violent reaction means that either the power supply is incorrectly connected, or the opamp's output is overloaded, or the opamp has crashed into large oscillations. The input single opamps in this design (OP604, NE5534 or TL071) are powered by +/- 18V, and the output dual opamp OPA2604 is powered by +/- 24V.
I suggest you check what you did exactly, and try to take a few steps back and get your preamp to work with 071 again, and that you go one step at a time and test the correct operation.
