sonolink
Btw, I just realized that I lifted the zener legs ONLY on the working channel. I never got to doing it on the faulty one. Does it make a difference? Shall I lift the ones on the faulty channel now?
Thanks to the measurement results, it seems to me that the faulty channel now looks good (unlike the "correct" channel where something is wrong with U3). You should now finally measure the voltages at pins 1 and 7 of the IC6 on the faulty channel for the different gain switch positions.
OPA604AP and OPA604PG4. Same price. Any difference?
I can't find OPA 2604
The datasheet says both orderable part numbers (missing an "A" in the second, should be OPA604APG4) have the same part marking, OPA604AP, so they should be equivalent parts.
OPA2604 is end of life and no longer available. OPA2134 was the TI recommended replacement, but it is only for power supplies up to +/- 18V, you can't use it with 24V power supplies. If there is not another set of regulators dropping the voltage to 18V you can't install a 2134 directly into the 2604 spot.
There are two test points labeled +18V and -18V on the first set of pictures you posted. Where do rails those go? I won't belabor the point, but I think down in your soul, you know what you need to do.
I don't see any op-amps capable of +/- 24V anymore at TI, and only LME49860 capable of +/- 22V operation.
Analog Devices has a couple that might work at 24V, but you would need a package adapter, they are SMD only, no DIP available any more.
Of course the whole discussion about +/-24V capable op-amps is moot if that location is actually running from +/-18V, you can just drop in an OPA2134.
Slightly off topic, but do you happen to know what Millenia does on newer models now that integrated devices with 24V supply capability are no longer available? Did the design drop to 18V supplies for all stages, or do new preamps have discrete op-amps for output?the output double opamp U6 with higher
I really do not know. All I know is that in some earlier preamps they used their branded discrete opamps at the output.Slightly off topic, but do you happen to know what Millenia does on newer models now that integrated devices with 24V supply capability are no longer available? Did the design drop to 18V supplies for all stages, or do new preamps have discrete op-amps for output?
In my experience, the good old NE5534 can work at +/- 24V with good passive cooling and not too much load. I discovered this quite by accident.![]()
I have definitely run 5534's at +/-22 successfully and feel like I would have seen that figure in a spec sheet before I tried it.I really do not know. All I know is that in some earlier preamps they used their branded discrete opamps at the output.
I'd bet that they bought a gazillion of them while they still could.Slightly off topic, but do you happen to know what Millenia does on newer models now that integrated devices with 24V supply capability are no longer available? Did the design drop to 18V supplies for all stages, or do new preamps have discrete op-amps for output?
I don't know how many companies still produce 5534/5532 devices, but the TI datasheet for their version of 5534 does say 44V max power supply. I don't know if that is different than the first generation devices or not.I have definitely run 5534's at +/-22
