maxwall
- Joined
- Nov 17, 2004
- Messages
- 1,134
I wanted to help a friend who wanted to see if it were possible to design a regulated power supply for a U47
with a VF14 tube . The power supply is currently outputting a unregulated 105.1 (+/-) 1-3 VDC to the microphone.
I thought about it and the TL783C regulator came to mind. Below is a schematic of how to implement the
regulator after the last filter capacitor or RC capacitor in the chain. Generally to get the voltage to a unregulated 105 VDC I would adjust the value of the last dropping resistor in the unregulated RC network (stock power supply). The value of that resistor is 1K, but found a resistor of around 850 to 950 Ohms would dial in the correct voltage for this tube microphone. I then would check voltages inside the mic to determine that the mic was distributing voltages correctly to the tube heater (VF14 - 36VDC ) and the plate ( 34 VDC ) and the capsule ( 63 VDC ) according to schematic. And the mic sounds fine. However, can the 105 VDC be regulated or is it better to send a regulated 36 VDC to the heater removing the large 1780 dropping resistor inside the mic and leave the 105 side unregulated for plate voltages etc.
Schematic 1(above) , Also what is best for R1 and R2 to get 105VDC ? R1=82 ohm R2= 6800 ohm (104.9 VDC regulated )
Schematic 2(below), U47 unmodified power supply ( unregulated )
Also should I use a 500ma or higher 120VACin to 125VDC out power transformer with a rc network that brings down the voltage to the TL783C regulator to around 106 VDC unregulated ?
Also , I noticed that Gyraf uses an array of 39V zener diodes to protect the regulator from unbalanced voltage swings. they sit in series above the protection diode. In my case I would probably use some zener diodes that were rated for a closer match to 105 V, yes ?
Schematic 3, Gyraf TL783 used for plate voltage(taken from G9 PS). How does R34,R35,R36 when plugged into the formula make for the regulated voltage needed to get to +245. Confused ? does R34 and R35 below combine as the equivilent to R2 and R36 as R1 in above data sheet ( schematic 1) Above ?
