sonolink
C)
And make sure your chosen connectors will work with the conductors in the cable. All Cat-x cables are not the same!For headphone cables, it can be CAT 3,4,5,6,7 or 8.
Chose a cable with as heavy, stranded conductors as you can find.
It is OK to connect the headphone negative terminal to the cable shield / ground. Just don't connect anything on the headphone side of a transformer(s) to any of the 8 cable circuits. You are using (per post #114) a bridge-tied amplifier, TDA7297 based, and that amplifier wants a balanced, floating load. All four amplifier output lines must not connect to ground.
For a given load the only way to get higher power into it is to drive it with a higher voltage. Power = voltage squared divided by impedance. The TDA7377 gets its higher power rating by tolerating a lower impedance load, which is not readily changed unless you find different transformers. Since you want more volume (more power), that means more voltage is what is needed. Run the amplifier at its maximum rated operating voltage, 18V, but the load is relatively light so it won't take all that much current at 18V. An 18V 2A supply is probably overkill. Note that the smaller TDA7297 as well as the TDA7377 runs at 18V maximum, so the more expensive amp doesn't help. (https://www.digikey.com/en/htmldatasheets/production/5227849/0/0/1/tda7377).
Like the TDA7297 the TDA7377 is class AB, it should not be radiating noise to other devices like a switching (class D) amplifier would. (Sorry for needing editing to get this right.)
Why not use a single RJ 45 connector that accommodates ethercon or rj45 and solders straight to the pcb?
Like post 128?
Neutrik NE8FBH range of products
https://www.mouser.com/ProductDetail/Neutrik/NE8FBH-S?qs=Lrve3rxDCt%2B6nu4OiHmhKA==
Im sorry, I assumed this was for a A box and a B box. Whats the build quantity? There may be suitable European sources. $11 ish in singles.The link you provided implies a cost of more than 350€ + shipping only for those connectors......need I say more?
I'm afraid there's a misunderstanding here. The externally accessible RJ-45s are Type-D connectors:And how are you securing the externally accessible RJ-45s? Typically they PCB mount.
Very good point actually. I hadn't thought about that and the same thing happened to me with a cell phone protecting coverNow that I understand the packaging better I think you are good enough to be successful. Just make sure the holes to access the recessed headset jacks are large enough to accept the body of the mating connector. I've had issues with cellphone cases that wouldn't let me plug in an extension cable or adapter cable.
Damn, that's a very good point too!!If you have to bend the board to get the opposite side jacks in place you have a serious assembly issue. The PCB needs to fit in place without being stressed or solder joints may fail.
