Help with diode ID?
Ah, I see - I misdrew the ground connection on the T3BM.
R202 is just part of an RF filter, along with R201 on the other input pin (with C201 and C202).
I just meant no source resistor to ground, as commonly done.
It's also the galvanic connection to the less positive source.
Somehow, it goes to ground, albeit in a tortuous way.
Ther are many ways to skin a cat, and many ways to power an element. Ground is just a convention.
Their were a whole series of diodes that had a drop of about a diode and a half, that were very stable and used in many discrete op-amps for current source biasing. They aren't available any more, if you come across one, a regular diode in series with a Schottky diode comes close.
Interesting idea.
Anyone care to speculate on any advantage this biasing method may have compared to a simple source resistor?
That would make sense, since there's no zener in this.
There's a lot of confusion here, since googling ISS226 results in three different diodes, only one being a zener.
There acid test is to measure the voltage across it. According to measurements on the schemo, I suspect it's a low-voltage (about 2V) zener.
It is not an "I" it is a (one), 1ss226 and this is two normal diodes in series, that is 2x 0,65V = 1,3V. 2x 1N4148 (in series) or a BAV99 should do the trick.
OK, so that means the FET in the capsule operates with this very low voltage. I'm not sure what is the advantage...?
1,2V (1,5V) is a "normal" voltage for the FET's used in electret-microphones. The "advantage" is that it can be operated with a single 1,5V battery (too). The current source shown is probably a 2mA current source. A selected FET with shorted G and S should do the trick.
FWIW, the modules in question do not have a battery option - they are phantom only. All the AT modules I've seen the schems for that have a battery option use a simple source-to-gnd resistor (AT8531, etc.).
I copied the schems carefully (despite my drawing error on the input pins) - the AT schems all show that diode with the standard diode symbol; not as a zener.
It'd be a bit surprising if the circuit is operating the FET at that low voltage; the specs for mics using this powering circuit state 138dB max. SPL
Just re-confirmed the voltage I noted on my drawn schem.
On the center tap of the xfrmr: 40v (what my mixer generates).
Between each pin the FET connects to, and ground (so between drain/source and gnd): 3.6 - 4v (with capsule/FET connected).
Yeah, that circle-drawn diode aways puzzled me; never seen it before - that's the way it's shown on AT's schems..
Voltage at the output of the 2SA1174 is 2.2v.
Voltage on the source is 3.6v
Well that's a pretty standard symbol, but TBH I thought it was something like a connector, the way it was drawn.
- that's the way it's shown on AT's schems. It's a glass diode on both the SMD and through-hole boards, not a FET.
Current regulating diodes are actually FET's with only two pins.
Hmm - even the glass ones? - didn't know that.
I know this is frustrating, but as I said, AT seems to have paid someone to toally scrub the internet of all schematics. Years ago every AT mic info sheet contained a schematic (though sans parts values).
I did find a scan of the AT8532 PM, but it's so low res I didn't think it would be of any use.
    86.5 KB
