midwayfair
sonolink said:According to what you say Q3 is then necessary to maintain the pedal original nature right?
I still can't figure out why it seems to be on all the time and Jones suggestion seemed an easy way out....
The FET has no effect on the sound. It's being used as a switch. It's either 'a lot' of resistance when the pedal is on -- and the feedback loop resistance is controlled by the resistor in parallel -- or it's 'almost no' resistance as if you'd just shorted the op amp pins.
The other transistors performance RM a different function and have nothing to do with the bypass.
If removing the FET made your LED stop working, then you have a mistake somewhere. The LED's cathode is connected to ground in one position -- so it turns on -- or 9v iin the other -- so it turns off. The LED has nothing to do with the audio.
Q3 has three connections: the source and drain connect to the op amp pins, and the gate connects to a resistor and diode for the voltage to control the switching. None of that affects the LED.
Get the LED working a and then return to the bypass switching.
In the meantime, you only use two of the switch's lugs for mechanically switching. They're just shorting the lugs, instead of using the FETvto do the same function.
