jsefer
Hello All, I have just finished a project, I transplanted the Akai M8 mono blocks into a 3u enclosure, and modified them to take in 4 mic-inputs. Attached is the schematic.
Referring to the schematic I made a few adjustments.:
1. I removed the power section [everything enclosed in red] so you can disregard that.
2. I changed the 500k R10 resistor to a 10k to match my input trasx
3. C9 and C11 were replaced w PIO .1uf caps
4. C10 and C2 were replaced w 100uf/25v
5. R13 was changed to 100k to stabilize voltage.
6. I split the sections so they get power independently from the power-supply and are not in series.
My problem is this: I have 2 monoblocks, one of them works perfectly. The other only the EF86 stage works with out faults. The 12ax7 stage, something strange is happening.
As soon as I power it up, the Gain wich is VR1 500k on the 12ax7 stage, does not seem to have effect when turned, and the output volume has little effect. Also, there is only sound for about 5 seconds then it fades away.
I already checked all my wiring, and compared it the working unit and they seem to be exact. Can anyone help me try and give me some places to try and check to see if I can get this to work.
I appreciate anyones time that can help me try and get this working.
