jsefer
pucho812 said:hmmmm. o.k. I had to ask as I had a similar problem with an amp I had on the bench and it turned out the bridge rectifier failed. but you have ac heaters so not a problem. Do you have access to an o-scope and a tone generator? Might be time to start to scope it out. Also double check all the solder joints and such.
No access.... im SOL in that department...
