chriss
Ladies and Gentlemen!
Is there anyone around here who has schematics for the Object mentioned in the Subject-Line?
This Amp has VCA's in each channel that can obviously be controlled via a voltage applied to a 5-pin on the back. What is this for? I'd like to bridge the VCA's since a) I don't need them and b) the VCA's are on Plug-In-PCB's that are very unreliable and already caused some trouble after transportation. Just I don't know if the Level-Faders on the front also control the VCA and if I have to bridge some connectors on the main PCB (I'm almost sure I have to).
I use this as a monitor Amp for my NS10 btw...
Thanks in advance
Chris
Thanks in advance
Chris
