Thanks everyone for responding to my post. after browsing a bit, i guess i understand that a tube needs two dc voltages supplied to it to make it work in an amp - one connected to its plate and the other " heater" to warm the tube . In the case of AKG c12 vr mic, the tube plate needs +120dcv and the heater needs +12.6dcv.
I have bought a Chinese tube psu and carried out some tests.
Results
Pin 1 +117.6dcv
Pin 2 +6 to 7 adjustable inside the chasis
pin 3 ( referred to as pointing adjustments from 0.0 to 100dcv depending on positions on the adjustment pot, I think this is pattern selection)
I think I can use Pin 1 117.6v to power the mic's plate ( akg schematic want 120v). Photos of this psu enclosed with its schematic diagram)
Now the heater requires 12.6v which is not readily avaliable in this psu. So I intend to use an external psu with 12.6dcv specs. What I need help is how to connect this 12.6v external psu to the heater pin. I undetstand that + terminal to that + pin as stated in akg's schematic but the - terminal of this external psu to ground ? I guess there is an external circuit created for supplying the 12.6v here. So to complete a circuit the - terminal must be connected somewhere. I hope someone would help.
