TheGuitarist
I know on a couple of guitar pedals i've used a little plastic thing that has double sided tape on the bottom that sticks to the case and then a wing type thing that goes through the holes in the pcb.
Just wondering if there are any better ways or if anyone knows where i could source something. I suppose on projects that generate alot of heat like the pm660 this wouldnt be ideal because the glue would go soft.
Been searching, http://jaycar.com.au/productView.asp?ID=HP0760&CATID=32&form=CAT&SUBCATID=549
is that what i should use or are there better ways?
