Trystin Stobbart
New member
- Joined
- Feb 27, 2025
- Messages
- 4
I'm looking at that circuit because I have no idea how to build one and it seems easier to find a simple 414 circuit and modify. The body used really doesn't matter to me I'm just looking at circuits as per the title.Why THAT particular circuit? If anything, your bigger headache WILL be the mechanical side - i'm not sure the mic body that board set was designed for, CAN physically fit any switches, so...
If you can't use that body / PCB, why get stuck on that "circuit" (as opposed to using the original circuit, which that one's inspired by)? Also, the one you linked is for a cardioid-only mic, so for multipattern you'll need either an insulated-backplate capsule, or a much more intricate switching arrangement, both of which will require more physical room to begin with, so...![]()
Appreciate the response, I'll look into those!Try modding a Takstar TAK55 or SM-18 PRO microphone, whose bodies follow the shapes of the C414 archetype. They have all the switches that you asked for built in. And then try to fumble that EB circuit in, like @Khron proposed.
Jan
Very helpful thank youWell, if you mean circuit, that makes sense, apart from the circuit not being explicitly published on that board-buying page.
But if you mean circuit board, then as i implied earlier, you're gonna have a hell of a time shoehorning a random board into a random body, nevermind the potentially-iffy results...
Just saying, be clear about what you want / what you're hoping for. THEN we can see about helping you reach those goals![]()
