I'm looking for a replacement xformer for an amp. I can't find it based on the markings on the xformer itself, but it's used in a simple rectifier circuit to create 12v dc for a relay that passes power through the main power xformer. The xformer I currently have is only producing about 8.5vac, which is not enough to close the 12v relay fully, which results in problems, heat, etc. I've tried to find a similar xformer with roughly 9:1 (or 1:9?) ratio that will convert 115v to roughly 13v, yielding about 12v after voltage drop through rectifier, but I'm unable to do so. I'm not even sure what specs I'd need to enter in @ Mouser to find this one....there are sooooooo many!
Can someone help? The amp itself in about 700W RMS, claimed 1400W peak, so the xformer needs to be able to hold the 12vdc/120vac relay closed at that type of load. Thanks in advance!
