I honestly recommend using Room EQ Wizard Software
It's Amazing and Free!
http://www.roomeqwizard.com/
Features
Frequency response measured using logarithmically swept sine signals for fast, accurate room acoustics and audio analysis measurements using an SPL meter, USB measurement microphone or analog measurement microphone
Real Time Analyser with up to 1/48th octave resolution
Spectral decay plots, waterfalls and spectrograms
Impulse response, step response and energy-time curves
Reverberation times derived in accordance with ISO 3382 in octave or one-third octave bands with results for Early Decay time (EDT), T20, T30 and an optimal fit RT60 figure, impulse response can be displayed with octave or one-third octave filter applied
Harmonic and intermodulation distortion measurement
Signal Generator offering sine waves, square waves, dual tone signals, CEA-2010 tone bursts, linear and logarithmic sine sweeps, random pink noise (full range, speaker calibration, sub calibration and custom filtered) and periodic pink and white noise
Sound level meter with full integrating functionality including equivalent sound level and sound exposure level; mic/meter and soundcard calibration corrections applied; A, C or Z weighting
Phase & Group Delay (measured, minimum and excess)
Phase wrap/unwrap, minimum phase generation
Impedance measurement and Thiele-Small parameter calculation
Impulse Response delay calculation and adjustment
Measurement arithmetic functions, add/subtract/multiply/divide/merge measurement
Automatic identification of peaks in the response, automatic assignment of EQ filters to peaks and optimisation of filter parameters to counter the peaks and track a desired target response
Waterfalls of predicted results of EQ can be viewed in the EQ panel and can update live as filter settings are adjusted
Support for the Behringer DSP1124P, FBQ2496 and DCX2496, QSC DSP-30, Crown USM 810, MiniDSP, ADA, Emotiva UMC-200 and XMC-1, waveFLEX DSP A8 and Xilica XP2040 equalisers
Room resonance analysis to determine the frequencies and decay times of modal resonances with pole-zero plots of the response and any filters applied
"Modal" filter setting provided for parametric EQ filters to aid in correcting modal decay
Room Simulator
Frequency response import from and export to text files
Impulse response import from WAV or AIFF files
Export impulse responses of measurement or filter settings to WAV files with 16, 24 or 32-bit resolution
Compensation for C-weighting when using an external SPL meter as the input, calibration files can be loaded for soundcard, microphone or SPL meter
ASIO support
Comprehensive help files within the application and on-line
