How is this an active attenuator?
Ethan
Administrator
Admin
Moderator
DC
When looking at the attached schematic, I see a diff-amp with an inverting stage to produce diff-out at near unity gain.  Where's the "active attenuation" that That Corp is referring to?
[quote author=That Corp Datasheet for THAT5171, pg 10]For better distortion performance with high- quality A/D converters, and to improve common-mode rejection, consider circuits like the one in Figure 6. The active (buffered) attenuator provides differential drive to the ADC, which improves performance.[/quote]
Here's the link to the datasheet (page 10, first paragraph): http://www.thatcorp.com/datashts/THAT_5171_Datasheet.pdf
Am I missing something? ???
are they using attenuator in reference to the reduction of common mode pickup?
I suppose that's possible but confusing in context.  Before that paragraph is a discussion of "Figure 5" which simply has a passive U-Pad attenuator, without the diff-amp stage.
Perhaps Figure 6 was supposed to have both the U-pad, followed by the diff-amp stage (but they forgot)?
Note that one drawback of the circuit shown in Figure 5 is that it offers no common-mode rejection. The 1570 has unity common-mode gain regardless of its differential gain, as does the passive attenuator shown in Figure 5. This circuit 5 relies entirely upon the A/D converter’s common-mode rejection.
The image you cropped from figure 6 does the same as the u-pad (R9-R11), but with common-mode rejection. Note the heavy differential feedback resistors. It's not unity gain. (I didn't calculate, just what it reads at a glance).
One of the better app notes I've seen in a good while. Seems like quite the professional input stage. Thanks for posting.
The schematic you posted is "just" the buffer at output using for providing isolation of active feedback U circuitry from the output and for better CMRR. The active (buffered) attenuator  is the complete design with the buffer inserted.
Regards,
Milan
Agh!!  Thats what I didn't get.  Thanks for pointing that out Kingston and John!!!
