Hi all,
Built a 2ch tube preamp recently for a studio that sounded great on my bench, low noise floor, no hum etc. Sent it off to a studio and they are having issues with it inducing unusable amounts of hum in other equipment, most notably in the preamp directly above it in the rack, but even a few units down / to the right of it. I dont have a jam packed rack over and most of my testing was done working on this unit by itself so I suppose I wasnt set up for this to happen but now trying to help from a distance. The issue is directly linked to the offending unit being flipped on and off and somewhat proximity based so points to power transformer radiation, though the extent to it being an issue is somewhat surprising. Could this also be a pin 1 problem? Or does that only manifest in the unit itself.
The power transformer is mounted on the rear of the unit which I didn’t think would be a major issue as plenty of tube equipment mounts the transformer it off the rear, but apparently not the case here. My initial recommendation is for them to try remounting elsewhere in the rack, however if it is messing with units a few spots away I cant imagine itll be a smoking gun. The power transformer has no end bells on it - is this likely making things much worse / is this the root of the issue? I assume my best bet is providing them with a steel project box or some mu metal foil to mount over the power transformer? Would like to not have it returned.
