I have sold all of the remaining boards, unfortunately. However, you could try contacting @Kevin at Link Audio. He purchased a few extras from me that he might be willing to sell if he still has them, and he has metalwork too.I got some of the boards from Ian way back, along with some 500-series in/out pcbs from JLM with the intention of building exactly what's realized in this project. But now I want this instead
Thank you ! You just saved me a ton of import taxes!706-71BDF30-02PAJS
706-71BDF30-01QAJN
If you look at the "part number aliases" they show 71BDF30-02-1-AJS
I don't know why they do that
I’m not familiar with MCE, but they’re probably fine. I’m building one pair of mine with all matched polystyrene, and was able to get 1000pF up to .01uF Xicon from Mouser. The .015uF to .1uF are a mix of Mallory and EPCOS from Tedss, which made it a bit more costly because they have a $20 minimum per item, but they had all the ones I needed. I recommend placing the components that are around the caps first, as the physical size will require some creative placement, as you can see in HerbertR’s earlier post.I'm very tempted to go all polystyrene cap route..
Anyone has experience with MCE styrene capacitors? I did some research but couldn't find much about them
The curves are very broad (low Q) so a small shift in frequency will be unnoticeable.I'm having a bit of trouble finding a 5n1 polystyrene capacitor without spending too much , would a 5nF be an issue or it just shifts the frequency a bit?
Perfect , thank you Ian !The curves are very broad (low Q) so a small shift in frequency will be unnoticeable.
