I was surprised a bit at the .1 A rating of the unit given the size (TO-220 device for scale). Would this only be suitable for preamp or processing sized loads or is there a small efficient power tube that could be used for a little power amp?
You also could build a series regulated PSU with tubes (6CA7) for your preamp. This will help drop the voltage significantly. http://www.r-type.org/articles/art-126.htm
