I found this 12bit scope for about $400. Has anyone tried it? OWON XDS2000 Series 2CH Decoding Economical Digital Oscilloscope
I don't know this particular one, but it looks to me like you would have the cons of CRT (bulk) and digital (not adequate for observing glitches), and only a few of the pros of digital.I'm looking at a Tek 2430a for sale locally , 95 euros , appears to be in good condition
It seems to be the only model in the 2400 series thats digital , 8bit,
its still a CRT scope but has some extra measurement features .
It dates from the late 80's early 90's.
The Tek 2400 series seem to be maybe the best analog scope you could find and come with lots of recomendations but does the 2430a pose any limitations due to it being digital 8bit ?
Just looking around the 2430a seems to have certain issues that crop up , I guess it was new technology at the time and maybe not as reliable as the rest of its siblings in the range . any input welcome .
I haven't tried it but I haven't read the best comments about these scopes. I guess there's a reason why 12-bit scopes cost thousands of $$.I found this 12bit scope for about $400. Has anyone tried it? OWON XDS2000 Series 2CH Decoding Economical Digital Oscilloscope
A Friend brought over a hand held DMM/Scope combo from this company the other day. I checked ACV accuracy and it wasn’t very good. I believe 1.228VAC as measured against an AP P1 and a Fluke 287 measured 1.246VAC. I didn’t look at the scope but I assume it was as bad.I haven't tried it but I haven't read the best comments about these scopes. I guess there's a reason why 12-bit scopes cost thousands of $$.
Historically, oscilloscopes were not precision instruments. A CRT could drift by almost 5% over a couple of hours. It's only when they integrated digital displays that they started to be more accurate.A Friend brought over a hand held DMM/Scope combo from this company the other day. I checked ACV accuracy and it wasn’t very good. I believe 1.228VAC as measured against an AP P1 and a Fluke 287 measured 1.246VAC. I didn’t look at the scope but I assume it was as bad.
My position is cheap digital oscilloscopes are not terribly good for audio.Tabletop or pc based scope?
I think that the popular Chinese scope brands are "fair", for example Rigol, Siglent, GW Instek, etc... I recently bought a GW Instek, much more expensive (circa $1000 USD ) because it includes spectrum analyzer, AWG, etc... and while the scope has a lot of great features and many advantages, all the cheap Chinese scopes have issues, for example, in this specific scope the line wont "zero" out perfectly, there is a slight offset, its minor and it only seems to be a visual offset rather than a real offset, but this is the sort of stuff you should expect from these scopes. With the Rigol scopes I have also seen and read many stories in which they state that they have problems displaying certain signals and you need constant updates to fix many of the problems, etc...I’ve never used it for work yet but I got a good deal on this one.
Promises a lot!
https://www.amazon.com/Siglent-Technologies-SDS1202X-Oscilloscope-Channels/dp/B06XZML6RD/
The advantage of owning an analog scope is that you actually learn how to use a scope, whilst those who learn with a digital scope are obsessed with the "auto set" button...For many years i got by with '50s era 200KHz recurrent sweep single channel scopes. I think I had 4 of them go up in smoke before I bought a 20MHz Heathkit at a swap meet (which I had to go through and totally resolder). True enough, we all have budgets we must live within. (Almost) any scope is better than no scope, but a good used analog scope can be had for less than 300 Euro. IMO, that is a better deal than a cheap digital scope (and I have both) but I suppose I am biased toward what I grew up with.
Now, laugh with me: I have a Hantek scope that is loaded with bells and whistles, all of which work, but some work better than others. I was flipping through the menus one day, seeing which of these features were actually useful when I accidentally changed the language to Chinese! Fortunately I had been drawing a map through the menu tree as I did this, so I reset it to get to a known point, then was able get back to the language menu without too much trouble. Seeing Chinese appear on the screen was a real gut punch, thugh.
Most of the times I use a small and cheap 2.4" portable scope.
Whats that cheap scope that you use?
Could you please share the model or a photo?
One that doesn't expect much is seldom disappointed.Thats the crappiest thing I've ever seen, but I guess that if it works for you, then its ok
Isn't that just a modern advanced version of "beam find"?The advantage of owning an analog scope is that you actually learn how to use a scope, whilst those who learn with a digital scope are obsessed with the "auto set" button...
