Unfortunately only 8bit, but I'm not sure how much that would limit me in daily use . I find it quite sexy,
Have you had any personal experience with it?
I like my Siglent. The team also does quite a good job giving us free firmware updates with really large upgrades in functionality and value.
I just upgraded it again this month and got a Datalogger now. I had already bought a couple of quad-channel DAQ boards for an instrumentation build and wanted to script the scope to get Datalogger functionality, but now I can use the scope as is for that.
I also hacked it to double the bandwidth.
I also have a script running on my laptop so that I can have a dummy Siglent Waveform Generator giving signals to the scope. This allows me to use the scope's internal Bode Plot II (yes, they upgraded that too for free!) with an external signal generator of my choice and not only the allowed Siglent ones.
Someone on YT showed a very interesting newish Rigol sold as 2-channel and 70Mhz and he firmare upgraded it to 4-channel and 300Mhz (no joke, the 4 channels are there in hardware, just not active by default). That's more expensive than your budget but it's good to be aware.
I do not like the Rigol interfaces/UI though.
With my Siglent, I now have a 200Mhz DSO, with internal digital protocols decoding ability, Bode Plot functionality, Data Logger, and FFT on 4-Channels, web interface for realtime viewing and control. That last firmware upgrade also gave me Labels functionality which wasn't there at launch.
I'd say while a DSO is really good for many things, at one point, you'll still want an analogue scope as well for detecting some things that the DSO can't do well. I am still looking for mine in second-hand listings. I'd probably like a Tektronix one.
The only faults I can find for my Siglent are the following:
1. No independent controls for the 4-channels. Still very usable, and if I really want, I can look at the extensive documentation and script it with my own hardware controls if need be.
2. The snappable feet aren't too strong on extension: they snap back easily and the scope then drops an inch or so. I worry about damaging the clocks/crystals this way with time.
3. SMPS... What to do? This is a very compact DSO... I would have to design a Linear PSU for it all if I wanted a really super clean measurement system. The alternative would be to use my DIY AC Filter Box with it to tame some leakage currents.
It is a little box which makes me happy though.
I'm about to pull the trigger on the sds1104x-e. Is this the one you have?
I’m close to pulling the trigger also, but had been planning to get the sds 1202x-e. Any particular reason I should consider the 1104 instead - I’m just a rookie enjoying building a few mics and some outboard.I'm about to pull the trigger on the sds1104x-e. Is this the one you have?
I don't know how well the bode plot behaves in the audio range though. I would expect it to be pretty low resolution anywhere up to 10-15kHz. Is it the case?
Also, what puts me off is that people complain about the fan noise but oh well...
I'm also thinking on getting a siglent AWG but I still can't decide whether I should go for the sdG1032X (14-bit) or the sdg2042x (16-bit). The 16-bit one is almost twice the price of the 14-bit.
I do have a couple of old analog function gernerators so I'm not even sure if I need an AWG...
Also, I should probably mention that I already have an old Tektronix 2-channel 60MHz scope on my bench.
You may as well ask yourself if you need 200MHz bandwidth. Shooting for less BW may buy you a built-in waveform generatot, if available.I’m close to pulling the trigger also, but had been planning to get the sds 1202x-e. Any particular reason I should consider the 1104 instead - I’m just a rookie enjoying building a few mics and some outboard.
Rather thought I‘d be unlikely to need 4 channels and would be fine with the 1202 for the price but, like I say, just a rookie so don’t know what I’d be missing
Most new DSOs are also 8-bit. Definately all the cheap ones from rigol, siglent, etc that are being discussed here...I'm looking at a Tek 2430a for sale locally , 95 euros , appears to be in good condition
It seems to be the only model in the 2400 series thats digital , 8bit,
its still a CRT scope but has some extra measurement features .
It dates from the late 80's early 90's.
The Tek 2400 series seem to be maybe the best analog scope you could find and come with lots of recomendations but does the 2430a pose any limitations due to it being digital 8bit ?
Just looking around the 2430a seems to have certain issues that crop up , I guess it was new technology at the time and maybe not as reliable as the rest of its siblings in the range . any input welcome .
