You may want to try a common mode choke in series with the pickup leads.
Have been thinking about this. Something bifilar I guess for "politically correct behaviour".
Otoh, I got suprisingly good results with a dead-simple single-ended PI (C-R-C) filter that at the same time functioned as a "cable sim". Very succesfully removed the annoying "active sound" even when used with opamp buffers.
Unfortunately, slightly unusable with volume-pot-pre-preamp wiring, esp. with vol-pots without treble-bleed.
You might also consider tying the output of your single-ended preamp to the pickup shell through a resistor pad (inverse of your preamp's gain). Might do as much to reduce noise pickup and add a lot less preamp noise than the differential approach.
Have been scratching my head for a while and wasn't able to decipher that one. I have a vague idea, but could you post a snippet?
Did you by any chance mean to generate an attenuated inverted signal from the output and feed the pickup "ground" wire with it? So it will sort-of cancel itself a little bit? Not exactly like in this schematic, but vaguely-sort-of:
http://www.dself.dsl.pipex.com/ampins/balanced/balfig12.gif
(pickup would theoretically go in place of R4, R5/R6 would be used to set the gain ratio, "hot" would be dismissed, and "cold" would be used to set the circuit gain).
Or maybe something similar to this, but used in front of the opamp instead behind it? http://www.dself.dsl.pipex.com/ampins/balanced/balfig5a.gif So the "error correcting" would be injected @ pickup "ground wire" via gain-setting resistor divider into negative opamp input?
Or something entirely completelly different?
@Alembic circuits: there must be a SVF filter circuit in existence somewhere. That one was said to possess "Certain Mojific Powers". Personally, I haven't heard one, but have seen a "knockoff" schematic once on the internet. IIRC it was very similar to BBE enhancement process.
All this will take a bit longer than suspected, I'll have to buy some beaten-up guitar to make it a "testbed". Preferrably something with a removable backplate a-la active basses. Or maybe one of those cheap peaveys - they could become useable axes if pimped up properly ....
Funny thing is that my "expensive" bass with bartolinis, shielded cables, shielded cavity ... and boutique electronic picks up lights and CRT more than my el-cheapos with preamps I designed myself. Must be that I tweaked stuff "by ear" and the buzz & fizz irritated me so I filtered it out subconsciously
QUESTION @ NOISE EXPERTS:
How does opamp's noise figure affect this configuration?
http://www.dself.dsl.pipex.com/ampins/balanced/balfig13.gif
I mean - does noise multiply across both stages or does it somewhat cancel?
Reason for asking: low-power dual opamp chips are usually @40nV/sqrtHz or some @25nV/sqrtHz. A "generic"opamp version of the circuit would be much simpler and quicker to produce and reproduce with opamps versus a discrete circuit which would require more attention to detail.
In particular - how would TL062 fare in such config noisewise? How can I calculate that? My gut feeling is that there should be a slight noise cancelation, but I may as well be dead-wrong.
