How do you characterize "Fidelity impairments low enough..."
What are your metrics for fidelity?
I do not propose any metric. Many exist.
I simply suggest that any fidelity impairments need to below audibility or we have a problem with fidelity. By allowing a bit extra we make sure that multiple devices ins series remain inaudible. I also simply suggest that going beyond "no audibility plus a bit extra in case" confers no further audible advantaged.
I am deliberately non-specific as this is a foundation of audio/acoustics issue. We can debate what these fidelity impairments are and what limits are once we acknowledge the basic proposition as true. Much literature and material on the subject is extant.
I agree; that's exactly what I meant when I mentioned "IMD or slew-rate or rise-time measurements".
Any required, naturally. You are expecting me to come out with something "this and that is what really matters", I will not.
I don't know. We do know that with music 12% HD with H2 dominant are audible and not objectionable for an average SPL in the 90's dB, for example. Also that 12% H3 are audible and objectionable but 3% are not objectionable but audible under identical conditions. On the other hand under the same conditions 0.1% H2 and 0.025% H3 are not audible.
So clearly Harmonic Distortion is a fidelity impairment, but it needs a lot of HD by modern standards to be audible and more to be objectionable.
Yes, so clearly Speakers subject of very high levels of fidelity impairments in the traditional categories. Why does nobody demand -120dB SIAND (0.0001% THD&N) for speakers but routinely expects the same from a DAC?
I disagree. Very easy to say. At +20dBW (100W input) I want to see a 87dB/0dBW/1m speaker that has less than several percent HD at any frequency and single number percentages of HD below 50Hz.
Based on how HD works and adds, the speaker dominates HD, neither amplifier provides any audible contribution.
The same holds for all other "standard" parameters. Non of these amplifiers will cause audible fidelity impairments.
Obviously Amplifier 1 has "appropriate specifications" while Amplifier 2 is severely overengineered.
Likely Amplifier 2 will not only reduce the HD by 40dB over Amplifier 1 but also reduce your wallet content by 40dB more than Amplifier 1, while you do not need the improvements in HD, noise and frequency response it offers. That is what I mean with "valid design goal".
but for example cross-over distortion, which happens at low level, can be detected easily on speakers that have more THD locally.
As I wrote earlier, distortion from speakers is different enough to electronics distortion that a decently trained listener can make the distinction.
I mostly disagree. If we correctly evaluate distortion (THD & N is not it) then we can be clear what source of distortion dominates at a given harmonic.
However I think we can both agree that with a speaker having 87dB/0dBW/1m (0dBW= 2.83V) sensitivity (even a distortionless one) the following HD is inaudible:
1% THD (-40dB) @ +20dBW,
0.01% THD (-80dB) @ 0dBW,
Distortion H2 dominated and monotonic
0.0001% THD (-120dB) @ +20dBW,
0.0001% THD (-120dB) @ 0dBW,
It does not matter what is the cause of the HD, at these levels and with, in the first case the qualified distortion profile HD will be at audibility levels.
With a stereo pair of speakers the 0dBW SPL at 3m will be 84dB with a 2nd harmonic at 4dB ONLY in presence of a 84dB fundamental. That is guarateed to be masked.
With -120dB THD&N under the same condition any distortion would be at -36dB SPL, in other words 36db below hearing threshold.
All other parameters listed can be shown to be equally inaudible.
So for the purpose of listening to music using loudspeakers, both amplifiers can be - for the parameters discussed to be free from audible fidelity impairments, despite offering different levels of signal fidelity.
Do they still sound different? Good question, but that was not the question stated.
So what do you suggest to replace or complement the usuall trilogy (BW, S/N & THD) as objectve measurements?
I suggest to use whatever audible fidelity impairment can be shown by suitable scientific evidence to be relevant, which may or may not include the "usual trilogy" and to include limits for audible fidelity impairment for each metric also backed by scientific evidence.
Otherwise we literally behave like our drunk looking for keys under street lights because that is where the light is, but not the keys, or like the practitioners of what Richard Feynman calls "Cargo Cult Science":
Cargo Cult Science
Thor
