I 've 3 sample of each value, wilco have sent to me months ago, they're big in size,(hig H volue) they got +/- 20% tollerance
I'm plannig to mount it diretctaly on the switch, I Would to know if some of you can create a schematic using the Fred Forssell Single Amplifier 4 Band Passive EQ topology with the "Fred Forssell vacuum tube opAmp
"http://www.forsselltech.com/schematics.htm. with in/out trasformers
if someone got time to do it, please test his behavior on simuletor, I use only Apple, and didn't foud one easy to use, or maby I'm not good to work with.
ones fred told me that this OpAmp got a 7ohm load, but he doesn't tell me if it can drive 600ohm or less.
well I have launch my idea.
thank you in advance :thumb:
P.S.
I've post the same question 2 yars ago, but at that time nobody seems to understend me. :green: due to my broken English :green:
