RuudNL said:So: from what I read it seems impossible to put the knobs on the slide switches back when you have removed them? :-\
Are they glued?
kingkorg said:Yes. High end is stock roughly in between modded and C1.
I am really sorry for graphs looking like this, it's very, very, rough way of just presenting what is going on. I simply do not have time to move speakers, change the room, it would be too time consuming.
However i think i found the ultimate, and possibly easiest way to flatten out capsule response.
I tried varying almost all the elements of one of the capsules today. Closed holes, used thicker spacers, even put thin mylar dot between membrane and backplate to simulate center termination, I thought i could widen the holes, but just before that i found an element that directly impacts response of high end, with little to no effect on polar pattern.
It's these copper washers between metal and plastic backplates that determine volume of the air chamber. There is two of them. Remove one of them, and you get instant hi end boost and crazy 7K peak. I added one washer made of thinnest paper i could find today, everything up to 5k boosted for about 5db, i got -3db bell cut at 7KHz, and rest of high end remained at the same spot. That would say i got -5db of very linear HF reduction with no roloff, and additional cut at very harsh sounding spot. And yes, it was actually boost, so capsule sensitivity improved. I guess membrane is too dampened by stock chamber? Just guessing.
By the way, this is all in a flat, stock mic, without modded circuit.
However i think that is too much, as the capsule isn't so bright. This paper washer brought it into Oktava MK319 without HF disk world. I just want to make it as flat as possible, and flatten out that 7K peak it seems to have. I will experiment, and give you feedback. Shame i dont have a micrometer.
It seems that this backplate is exactly what Marek was tweaking. Just by looking at the picture of his mod.
kingkorg said:Anyone has an idea where we could find these grilles without capsules?
MagnetoSound said:I can't help but wonder why this is so difficult. Why does the AKG CK1 (series) sound so good?
If you take it apart there is nothing to it!
(Or the other screw-on capsules from Calrec, etc?)
ln76d said:Why - because it use different backplate pattern.
Some MBHO capsules also use similar backplate design and they sounds really good.
Marik said:Sure, it looks simple and as if there is not much into it. On the other hand, for example, look at the holes in that standard Chinese capsule--there are only 12 of relatively large diameter. On the other hand the CK1 has much more holes and their diameter is much smaller, so we need to spot the holes first, we need to feed the drill much slower, and we probably need to peck the holes. Smaller diameter means there is much bigger problem of tool breakage. Also, smaller capsule diameter means harder to hold the piece while drilling.
Just judging by machining time--that would take about 30 sec the most to drill out that Chinese capsule and some good 5-10min just for the front backplate alone on the CK1. Pay attention, the second backplate of the Chinese capsule is molded, so production cost probably somewhere a few pennies or so. The all other hardware probably made by a screw or Swiss machine, so also costs pennies on the large production scale. My guess, if that Chinese capsule was sold at wholesale for a couple buck a pop they probably still make about 100% profit.
Best, M
