RuudNL
Today I received my SubZero microphones.
First thing I noticed, is that the FET bias isn't optimal. (It is set with two fixed resistors.)
To optimize distortion and max. SPL, I removed the two bias resistors (470K and 82 K, on the center of the PCB, in parallel with the source resistor).
After you have removed them, there is just enough space for a small cermet trimpot. (I used 1 M.ohm.)*
With the correct setting, THD is around 0.02%!
By the way: I found a way to put back the knobs on the slide switches.
First you slide in the PCB. The knobs are inserted from the outside!
Put the slideswitch 'halfway' and put in one end of the slideswitch knob in such a way that it goes a bit under the surface of the body tube. Match the opening in the knob with the pin of the switch and press and slide the knob in the direction where you first inserted the knob. It will now click onto the switch and operate 'as before'.
* EDIT: In both my microphones, the value of the 470 K resistor was too high to bias the FET correctly.
The easiest way to correct this, is to replace the 470 K resistor with a 500 K. trimpot.
This makes it easier to adjust the bias correctly than using a 1 M. trimpot to replace both resistors.
