soapfoot
there are great solid-state mics. I'm not interested in making one right now, however. Maybe some other day. Right now, I'm interested in making a tube mic inspired by a U47.
Gus said:What about a solid state circuit?
Looking at the data sheets, I can already see that the filament voltage of the EF12 is 6.3V. I've seen it recommended (per Oliver Archut) to underheat it slightly, to about 5V or so. Seems that this would be most elegantly accomplished through a separate conductor in the tube mic cable, it seems. This much makes sense, and while it's obvious, it's at least a start.
gary o said:... as long as the cathode is biased correctly ......
... we could disconnect the heater, replace with dummy load, externally feed the VF14 with the 36V & the mic would still sound the same ???
rodabod said:... And you'd need to keep the cathode resistor the same value, thus meaning you'd need an external bias voltage source.
gary o said:Im talking about the E14 that im told is same as the V14 apart from heater & then mic should sound the same as with V14.... I no other DIYers & designers are doing this but I seem to read that it might not same sound the same I think it should be but not sure thats why I ask.....thanks for your patience
... which is sort of what Max does in the MK7...rodabod said:... And you'd need to keep the cathode resistor the same value, thus meaning you'd need an external bias voltage source.
and nobody seems too keen to share
zebra50 said:Well, we're all sharing! Really all the info is here now - 6V heater (or five if you prefer), and cathode bias from heater supply. Everything else as it was in the 47, then tweak til it sounds good.
gary o said:Hi Roda......please excuse my lack electronics basic knowledge......can we not adjust the mic circuit to bias tube from the 105VDC going into mic.....Im keen to understand this ......again thanks for patience.
soapfoot said:So what does it mean to get cathode bias "from the heater supply?" Do you mean take a small positive voltage from a 6v DC heater by way of a resistor, and apply that directly to the cathode, as opposed to using a resistor to develop the bias? And at that point does the cathode "float," with no ground connection?
Bias should be approximately how many volts negative?
