:David Kulka said:Is the actual switch in that photo really rated at 16 amps?
:It sure doesn't look like a 16 amp switch to me.
:But even if it's rated
:(or claimed, depending on how much we trust the manufacturer)
PL400 isn't "high power" amp.the construction looks very wimpy and I wouldn't use it for any sort of high power application
You're plain wrong here. Most power amps use ordinary power switches and some sort of inrush current limiters (NTCs, high power resistors) and/or low power controlled chunky relays and solid state switches.Most power amps use power switches with much more robust construction
scott2000 said:Thanks! Is that the resistors? Is the one a thermistor?
