frazzman
Hi guys,
I've always had problems with the brass inserts on SIFAM collet knobs 'spinning' on particular shafts.
It is mainly an issue when using them on stiff rotary switches, like the uraltone type.
What happens is the collet insert starts turning without moving the rotary switch.
This isn't a problem on D shape shafts where the brass insert can grab the corners of the shaft, which stop it from spinning.
Has anyone experienced this and have a suggestion on how to deal with it?
In the past I've used some strong adhesives on the shaft which does work, but it is far from elegant.
