interesting interstage transformer idea
edanderson
atlanta
maybe one of the varimu threads here has touched on this idea, but still worth posting:
http://www.philcoradio.com/tech/audio.htm
plan B basically uses a center tapped choke with the CT grounded to do the phase splitting.
ed
true, it is a center tapped coil (in this case the secondary of a transformer) connected as an autotransformer (with no isolation between signal input and output). though, i guess i've never seen an application of an autotransformer where some point in the center was grounded. likely there's another application for it though.
it would be unlikely to find a "choke" coil with a center tapped winding. maybe a CMR choke with two equal windings joined, though that would tend to be too small for interstage purposes. would any PA autotransformers have a tap right at the midpoint? i suppose a more readily available device would two windings of a multifilar transformer, connected as an autotransformer.
whatever the intended use of the original device, as dan points out, it would be connected as an autotransformer.
ed
[quote author="edanderson"]
it would be unlikely to find a "choke" coil with a center tapped winding. maybe a CMR choke with two equal windings joined, though that would tend to be too small for interstage purposes. [/quote]
I tried an edcor wsm 600:600 wired as an autoformer. both windings in parallel makes it a single 150 ohm center-tapped coil. useful for line output step up, step down or inverting. IMO it is straightforward to implement global feedback with these kinds of circuits. I havent seen hardly any autoformers in relatively modern audio gear. there is the LA-3A sidechain, McIntosh power amps, and? anyone?
EDIT: actually it wouldn't be 150 ohms, rather 600 but with half the DCR.
mike p
