TheGuitarist
So i was wondering if it is at all possible to build a large format controller for pro tools. I don't need pre's etc so a C|24 is useless and an icon is a ridiculously expensive route.
I'd Probably want a similar feature set to the VENUE Profile desks, all the usual controls, fader, channel select, mute, solo.
So for each channel I'd probably want: Select channel, mute, solo, record enable, make new playlist, then a trim control. This is all with faders of course and maybe a little display to show what channel is what.
Then apart from that, a master fader, an eq section, dynamics, send levels. Of course a button to change banks, and maybe a button to cycle through plugins on a channel.
You get the point. Just wondering if this is even possible?
