i am trying to set up a simple power supply with two outputs +24 and +12 VDC
i am using a lm317 for the 24v output and a 7812 for the 12v
i have been trying to feed the 7812 input from the lm317 output, thus cascading the two regulators, but this way it doesn't work. the output of the 7812 stays about 1.5v and the lm317 regulator gets very hot
i also tried feeding the 7812 straight from the rectified dc supply but it's not working either. i guess it's because the 37v i'm getting after the diode bridge exceeds the maximum input voltage rating of the 7812
is there a way i can make these two working together ?
i got the idea from the gssl power supply which uses a similar approach but works on different voltages, 15 and 12
i hope i can make this work because i have the pcb already done ! i just assumed it would work but again my lack of theory has proved me wrong
