its the MXL V67 mod thread again
Bumping old thread!
If I want to convert this mic to use a 10:1 output transformer (and nix the EF stage), I think I need to:
1) Remove D2 (PNP)
2) Remove R9 and R10
3) Remove C6
4) From hole in bottom leg of R10 (where it connects to output capacitor), wire a jumper over to the top leg of C6
5) Replace transformer
I believe R18 would need to be increased in value slightly to compensate for the lowered current due to removal of the PNP (to keep the drain bias the same).
i replace the caps to other better and the changes is minimal, but change the out capaticor (c8) to 1uf ... its the best audible change !!... recommended
Matador said:
Bumping old thread!
1) Remove D2 (PNP)
3) Remove C6
Matador, sorry to bring up a really old thread, did you ever complete this mod? Wondering if it worked. Thanks.
Did you read this thread?
http://www.groupdiy.com/index.php?topic=47569.0
