Hello everyone,
I'm new here and was wondering if someone might be able to offer me a little assistance on a JE-990 Circuit that I've been working on. I decided to try and learn more about discrete opamps so I thought the 990 was a good circuit to try and build. Anyway, I built one on perf board and to my surprise it worked perfectly the first time. So, I decided to draw up a PCB for another one. I did and now the PCB version is giving me all kinds of trouble.
The problem I'm having is that when I set the circuit up in a voltage follower configuration with all of the components in I get an output that is about 1/10th the input and is offset by -15V. When I take out CR1 & CR2 the output is equal to the input but is still offset by about -2V. On my prototype that I made, when I set it up in a Voltage follower configuration, it's at unity gain and there is no offset. So I was wondering if anyone had ever run into anything like this before. As far as I can tell there are no leads touching each other and no traces touching either and everything seems to be connected properly. I've A/B'ed it with the perf board one I did and it looks the exact same to me. Any toughts or help would be greatly appreciated. Thanks.
Brian
Brian
