mabell313 said:
What really drew me towards the Beyer trans was the size. You can fit those things damn near anywhere! What my question should have been was how does the Beyer, which is a high quality trans, compare tonewise to other transformers i.e. Cinemag, Jensen, Sowter, Lundahl. Is it clear and hi fi? Warm and rich midrange? I am stoked to get a few of those transformers now! Lots of 7:1 and 10:1 Beyers floating around for cheap.
Talking about sound is like singing about tax policy...(sorry it is early ... there is a better quote)...
I can tell you that I did several Royer mods, but two LDC Royer mod mics... one with the jensen direct box 12-1 step down (for get the number Jt-db-e or something) which is advised in the article... and one with the beyer.
Everyone that uses the beyer one loves it (a good sax player, and a great double bass player have both said it gives them better sound than they have ever gotten before).
I think it has a texture somehow.... and even though both mic's use the same capsule and a similar circuit, I think that there are individual capsule to capsule differences that make for the difference.
(In the one folks like, I shortened the mic to tube lead by having them co-reside in the basket, so it glows.... maybe they are just woo'd by the sight of it!).
In any case I can't tell you why but it is a beloved mic. I have some AKG C414-TLII's and this Royer beyer mic has a much less pronounced top end (those mics push the "air" range pretty hard) and is very rich sounding.
I thought it was the capsule just happened to be a good one... or the fact that I cleaned out the head basket ... maybe it is the trafo...or all three.
I used a little 1:10 Beyer with 1 primary and one secondary and no center tap. I have specs for it from the 1974 beyer list. It is a 7 pin mount version of the trafo, and I have made an eagle part for it. However in the mic I just carefully solder to the pins.
I have also used them for a Hi-Z input ( I protoboarded one of silent arts/classic API's Hi-Z modules with one as a step down, it works.).
Anyway if you want one, I have several left PM me and I will shift one. I just bought a couple of similar beyers on ebay, so if you want I will shift you one or more of these at the same price. If you are interested, let me know I will send pictures, model numbers etc. Each one also has a date stamp.
By the way the jensen direct box trafo is a very small trafo that fits well in those metal trafo cases MXL cases down near the XLR (in the existing shield cans)...
I don't know about the U87 mod is that a tube mod?
b
