mac
Hey Baadc0de ...... saw your old post on the JLM forum and thought you may have some comments here.....
how is your dual 990 going anyway??
I have the JLM99*MB kit and am putting it together with a pair of Fred Forssell fet992 DOA's... Looking to use an OEP on the board, so Joes schem for the dual 99v with the OEP provides a great starting point.
also found a schem from Fred which shows the servo option, which I am implementing ......
http://www.forsselltech.com/media/attachments/Dual_Amp_PCB_Schematic.pdf
So now some questions.
I want to implement a High/ Low switch with a DPDT toggle, which throws the ratio jumper on the OEP. CL will remain fixed at 220pf for both ratios, but the table on the JLM website suggests 27k for the low ratio, and 100k for RL in the high ratio. Any comment on how critical RL would be here, or should I switch via a relay that throws the jumpers and the RL values?
Fred's schemo uses 33pf for c10 and c20, and 10k at r16 and r23, so I shall use these values.
R13 and R21..... The Jensen schematic which you used for your 990 applies 15k and 301k in these positions, but Freds design is using 49.9k for both positions.... (I don't think I understand this at all...)
R24 and R25 are slightly less at 49.9 ohms (which is probably insignificant), however the Forssell design omits the output caps at C23 and C24, which I presume is because there is no output transformer. I am planning to do listening test without transformers and then with a few different trafos. Should I omit these?
Mac
Mac
