A quick hello to everyone on the board, have not been around here for a long time as have been without internet access. Good to see the board still going strong.
I had posted a previous query about the John Roberts parametric EQ circuit featured in an old 80s magazine article but couldn't find it or anything related with the search function so I put this one in a new thread...
As I'm lost in a remote corner of exico and working on a low budget I am always trying to scavenge parts and have an old mackie console here whuich is full of center detent pots, perfect for the eq sections i want to build. Problem being the pots are 50K, and therefore not an exact match for the 100k boost/cut controls. Would changing the pots be as simple as scaling down the gain setting resistors on the input amp, bearing in mind each individual section will be fed froma low impedance source (buffered)?
If John or anybody can provide me with a method for working this out or simply a yes you can/no you can't answer I'd appreciate it, thanks..
