ricothetroll
Hi !
I took this hi-fi amplifier out of my basement after it has been there for a few years. When switching it on the first time, I heard the protection circuit relay clicking, indicating that things were going OK in the power amp, at least from a protection circuit point of view.
I left it on during an hour or so while I was fixing the speaker I wanted to connect it to, and then when I finally connected everything the amp was not working anymore. And there is no relay click anymore after switching it on and off again.
I got the service manual and checked a few DC voltages. It appears that the bottom channel (on the joined schematic) has correct voltages, while the top channel has a wrong biasing of the whole driver/power amp circuit: the base voltage of Q13, Q15, Q17 and Q19 if around -17 VDC instead of the expected +/- 1.2V and +/- 0.6V.
I have desoldered and tested all the transistors and diodes highlighted in green on the joined schematic, but they all tested good. I'm running out of ideas...
Would anyone here have a clue about what could have gone wrong in that amp ?
Thanx in advance !
Best regards
Eric
Thanx in advance !
Best regards
Eric
