First of all, thanks a lot to
@chilidawg for this thread. It was helpful in troubleshooting my own problem with those monitors.
Some background. There are multiple versions of the plate amps used in Solo6 BE. I don't know how many revisions are there, but there are at least two distinctive features that tell them apart. One is the already known difference in the switches - the sensitivity and voltage switches on the backplate. The older version has a metal toggle switch for sensitivity and a plastic rotary switch for the mains voltage. The newer version has slider switches for both and is known to be more mechanically reliable.
Old version (image from the internet):
New version:
There's also another, more recent version of the plate amp, supposedly used in the 40th anniversary edition of the monitor. It can be bought as a spare
here, and the "V4" in the name suggests there's also a 4th revision of the amp apart of the three I mentioned.
What no one seems to mention is that there are at least two completely different designs of the circuit - one based on integrated amplifier chips and another one on discrete amplifiers with Indigo BASH SIP module just for the PWM control. This thread has a lot of photos of the latter, e.g. this one:
As far as I can speculate, they initially built the woofer amp around the ST's
STA5150 and
STABP01 ICs (the first is the amplifier itself, and the second is the power voltage controller), but later ran out of parts (as ST discontinued the BASH line) and had to come up with an alternative design.
The monitor that I have has the old backplate (with the rotary voltage switch and no BASH logo), and the woofer amp is based on the aforementioned ICs:
Despite the differences, the failure symptoms are very similar to the ones described in the thread: the woofer either produced only hiss (no sound), or periodic crackling. Another one I haven't seen being mentioned is the dimming and blinking of the green power LED on the front panel.
After the initial troubleshooting a few years ago (which included replacing the STA5150 IC), the temporary workaround was to disable the standby/protection circuit by lifting the collector of the Q4 transistor (it pulls the standby/mute pin 11 of the amplifier IC):
That helped for about a year, but recently it started sporadically entering the LF crackling state upon power on again until eventually failing completely.
Interestingly, despite my two monitors having serial numbers a few digits apart, they had different revisions of the amplifier PCBs.
The failing one was labelled "FOCAL SM6 Issue 1.3" while the other, working one, had the "FOCAL SM6 Issue 1.31" label on it.
Nevertheless, the layout and component values both seemed to be exactly the same, so I've proceeded with comparing everything between the two PCB's. At this point I already had a particular suspicion that needed confirmation, so I've made a spreadsheet of all resistors - their marking and the measured values on both boards. I'm attaching a table with all values if anybody needs a reference.
Surprisingly, I've found a bunch of broken resistors! They all measure as open circuit. They are all in different parts of the circuit - some are in the preamp, some are in the poweramps, some are in the control circuit, so I doubt it's because of exceeded power ratings or something similar. More importantly, there's a suspiciously limited number of values that have been affected. For example, almost all 3.32k resistors are broken, so it seems like there was a bad batch of resistors.
After replacing all resistors of the affected values, and re-enabling the standby circuit, the monitor now works perfectly!
Hopefully this information will help others who happen to have boards from the same batch and are experiencing any issues.
