That is a strange phrase, what exactly do you mean by that? Are you referring to a complementary pair style amplifier, and only the negative voltage side is operating?
If you look at where the woofer's positive lead (red cable) and the negative lead (black cable) are connected to, what do you see?
because I see a layout and components that are copies of each other. Does this indicate a complementary pair? Idk. All I know is that when I checked the monitor that has no issue, voltages that appear on both sides are identical, within a very tight 0.1V tolerance.
Blue lines surrounded the sections where the voltages are very different.
For the sake of simplicity, I named the two Solo6 monitors as GOOD and BAD.
And some measurements:
U501 near the 47uF/35V capacitor, which is a TL082C op-amp.
Pin 1 is connected to a resistor (R513) in series with a BAS16 switching diode (D514)
GOOD: pin 1 is -13.6V, anode -13.6V, cathode -13.9V
BAD: pin 1 is +13.2V, anode +1.6V, cathode 0.9V
Q309 next to the trim pot P300, a MMBT4401 PNP transistor.
GOOD: base +1.65V, collector +13.2V, emitter +1.1V
BAD: base +4.0V, collector +14.9V, emitter +12.6V
D307, a BAS16 diode.
GOOD: anode -13.2V, cathode -13.8V
BAD: anode -7.2V, cathode -7.98V
Not identical.
On the negative lead side,
Q31? something next to trim pot P301, also a MMBT4401 PNP transistor.
Both monitors: base +1.65V, collector +13.2V, emitter +1.1V
D316, a BAS16 diode.
Both monitors: anode -13.2V, cathode -13.8V
Identical.
I took these measurements many times, in different sessions. Always the same result, which is why I believe that the power supply is ok, and the negative lead side is also ok.
If they are truly switching transistors then all you can see is the DC average, so again you can't really tell much about what is wrong. If they are actually operating as linear devices then you can measure the base, collector, and emitter to see if they are biased correctly. You can almost do the same thing with MOSFETs by measuring the voltage at gate, drain, and source, but the on/off threshold has so much more variation than a bipolar junction that you have to do more work to determine if it is biased correctly or not.
Sorry, I meant to say switching diode. No idea if the transistors are also being used for switching.
Aside from the MOSFETs, they are MMBT4401, MMBT4403, MMBT5551S, MMBT5401S.
