Hey Guys,
I bought a rack of allison research gates in a pr10 powered rack,
i got them cheap as four are half working (pass signal and gate but sound slighly different - some crackels and hums in some settings) and three arent working, there is also a gain brain in there that amplifies signal (both in and out - but no compression at all)
I want to get them up to spec and at least have say 4 working well (drum kit duties)
I have print outs of the schematics and a basic manual, and have read all of the relevant posts on gdiy and gs
how should i go about fixing these.... (i can follow a schematic and have built a few things (1176, nite eq, guitar pedals) - but i have no formal training or experience)
i thought i might start by..
1) passing varied signals through all units in various settings and note what works as well as differences in settings
2) calibrate as described in manual
3) re cap and calibrate the broken ones to see if this fixes anything - (some of the caps look bloated at the lead ends)
the units all have those 100v lamps - most of these dont work and some flash on intermittently.
i have the feeling that these are adding to the zaps and noises in the signal.
i would be happy to disable these (and use my ears) if it made them more stable and free of artifacts ( i read a post on gs mentioning engineers who left them broken / blown so that they would not affect the audio..
i would be even happier if i could change them out to regular leds..
if any of you have experience in fixing / servicing these i'd appreciate your ideas
