AusTex64
- Joined
- Jun 3, 2013
- Messages
- 533
I’m trying to understand the feedback circuit in KM54. Here’s a schematic:
http://repforums.prosoundweb.com/index.php?action=dlattach;topic=36938.0;attach=2509
Specifically what does R2 do? I understand “abgliechen” means adjustment, balancing, tuning. What exactly is being tuned? Freq response? Gain? If I understand this feedback, it should reduce more HF than low. The KK54 capsule has a HF rise at 8K, and I think this feedback reduces some of that bump. I’ve been discussing this on Klaus’ forum, and a Neumann old timer posted a fascinating Neumann document that shows what the freq response of the buffer should be. It says -1db overall, and -3db at 16K. http://repforums.prosoundweb.com/index.php?action=dlattach;topic=36938.0;attach=2754
I am trying to implement this feedback scheme on some mics I built with a cathode biased, plate follower buffer, very similar to the KM54c but using a different tube. The mics use the M94 capsule, which I’m told is very similar to KK54. They are my “poor man’s KM54’s”. But they are a bit bright. So I started studying the KM54 circuit and figured out I don’t have the feedback. I’ve added the feedback to a mic as a test, as drawn on the KM54 schematic and it works, maybe too well. Weird thing is I used a 30K trimpot for R2, but it doesn’t seem to have any effect I can measure. What controls the gain of the feedback, R1or R2?
The other difference with my mics is the backplate is charged instead of the diaphragm like KM54. But this shouldn’t make any difference, right?
Thanks for any guidance you can provide.
