gemini86 said:
I'm still confused by your post... it seems (and forgive me if I'm way off base here) that you're looking for someone to solve your problem for you.
What are you measuring as far as continuity between head basket and case? less than one ohm? several ohms?
You're not going to get far with troubleshooting by asking "I have this specific problem and don't have any details as to what I've done to troubleshoot it so far... does anyone have an answer to my problem?"
Sorry to be blunt but I'm just trying to help you... help us... help you?
/grumpy ramblings
I hear ya... here are the facts
1. The Korby Kat is a "Two part" mic.
2. The top part, known as the "capsule" is made of metal.
3. The bottom part, known as the "body" is made of metal.
4. The Capsule shell needs to be at ground.
5. It achieves this through "outside contact" with the body at the "joining" seam.
6. There are NO wires, d-subs, snakes, jumpers, pins, etc... that "bring" ground to the capsule shell.
7. The joining seam can be "pressed", "tilted", "moved" to make intermittent contact, thereby "giving" ground to the capsule shell and fixing the problem (which as you may remember is ground hum)
8. totally open between the "headbasket and case" unless you follow #7
9. I tried cleaning the mating surfaces... it helped, but didn't solve it.
10. ""I have this specific problem and don't have any details as to what I've done to troubleshoot it so far... does anyone have an answer to my problem?""
ummm.... actually - The capsule shield isn't making good contact with the body... (**waring** details!!)
"I have used scotch brite on all the mating surfaces... still same problem.
Warning ** not looking for "does anyone have an answer to my problem?" LOOKING FOR "Has anyone had
one of these things cause a
problem like this? A SPECIFIC PERSON WHO HAS HAD THIS PROBLEM.
Love you!
