I now am running my LA2 with a 6SN7 driving a 6SN7 for the line amp. It sounds wonderful. Larger current requirements brought the B+ way down to the point where I only had 50 volts on the plates of the voltage amp, due to the 68 K voltage dropping resistor in the power supply, so I stuck a 10 K in there.
My question is, now that I am running a tube with an amp factor of 20 instead of the stock amp factor of 100 with the 12AX7, should I change the negative feedback network to match up with the 6SN7 voltage amp a little better.? Is so, what should I do, just play with the resistors a bit or leave it alone.
here is the circuit:
