andyfromdenver
*edit: problem solved. read on for fun*
Hi everyone, hope you are well.
Symptom: 1st ed LA-610 The compression stopped working.
observation/ tests: the anode resistor to the 6aq5 (6005) appeared a little worn, and the trace approacing the lead is darkened. The 6aq5, like in the LA2A provides gain to the illuminating EL in the optocircuit.
With a known good 6aq5, I tested little/ no DC voltage on the anode. With the pcb pulled and the resistor out of circuit, it was an open circuit.
Fortunately, I had mapped much of my old La610 before selling, and I knew that the value of the resistor was 210ohm 1W (edit: this value is incorrect, I was fooled by cooked color bands see below).
This was a first for me to see a resistor fail open. and it looked like brwn-brwn-brwn, 110ohm, so clearly it took some heat damage to brown that first color band from red.
So, I swapped in a 2W 220ohm as you can see in pic.
Now the tube is getting proper voltage, furthermore the blocking cap is working, and on the other end of that, I get an increase in AC voltage for increase in input signal and peak reduction knob.
But the EL does not light up.
Does this conclude that I will need a new t4ua (the opto circuit drop in)? They are $170.
Could a tube failure or the anode resistor failure cause damage to this? how so if the blocking cap is still good?
thank you so much for your time ;-)
Andy
edit: link for optocircuit part: https://www.studioelectronics.biz/sunshop/index.php?m=&c=158&p=4569&l=product_detail&my_rate=TWD
Andy
