ok... a racked pair of 1073s start makin' that low hum.
i'm thinkin' power sup. open it up, yeah the main filter cap is starting to leak.
it's sprague 4900uf 50 volts, 75 surge. i look around, and find a 7800uf 50 volts and stick it in there.
fire it up and check the output voltage andturnit from 23.9V to 24V.
next, i measure the voltage across the main filter cap. 77 volts. derrr
so thinkin' that's a little high for a 50 volt cap i turn it off.
the markings on the transformer are ABA-LNS-Y-24 the model number of the supply.
i can find no specs for this unit, like what is the output from the rectfier supposed to be, like i'm thinkin'
77 volts is a little high.
anyone have any info on this unit? or advice?
thanks
thanks
