benqbasic said:Hit them up about charging you to fix their design flaw.
Gus said:Are the orange blocks with fins at the right in the photo transformers or sealed DC supplies? Do they have a air flow path or are they enclosed without air flow? I can not tell from the picture.
If transformers can you get access to the terminals to check if they have an open wind(s)
Does it turn on at all?
If so can you scope the microcontroller(I am guessing there is a microcontroller) clock and data lines?
Do you have access to a thermal camera? Seek and Flir make more affordable ones, some attach to smartphones
Are there any pictures of a MK3 upgraded MK2 we can compare?
Gus said:If you get a good test tone out of the digital output but static otherwise as posted
this could be a number of things
Gus said:Are there two microcontrollers one for the buttons, test tone, parts that work and one for the A/D section?
Can you read the chip numbers? The larger ones might be microcontrollers.
Gus said:Are the DB modules in sockets? If so maybe you can mark them and remove one at a time leaving the other in and testing maybe one is loading down a common data buss or clock line.
Issue with this is we don't know the modules current draw and how much the supply voltages might rise with 1/2 the A/D converter loading could hurt other parts if the voltages rise.
drpat said:Here is a complete list of chips in the unit.
The one that reads "DSP56002FC66" looks slightly dis colored, like it may have undergone some heat damage.
Gus said:
